Hi @tonality and @etfrench
Thanks for posting! I found that the DXF/projected sketch workaround presented by @etfrench worked for me as well with your part. I also found that I experienced the same selection issues both of you described in the original file.
As the original file does contain some timeline errors, I expect that they may have triggered the poor selection. If you see this behavior occur again please let me know and we will look into it - thank you both for bringing it to our attention. I will be on the lookout for similar selection problems!
In the meantime, I found that I could either use the DXF workaround already presented or simply select the sketch geometry instead of the model geometry for the body that has been giving problems. I have also attached a file showing how to use a duplication pattern to make this programming a bit easier - you can go into the contour operation and add tabs wherever you'd like.
I did also notice that reducing the number of tabs around the problem body helped the toolpath generate more consistently - using fewer and maybe larger tabs may make this toolpath a bit easier to work with.
Hopefully that helps! Please let em know if you have any questions.
	Paul Clauss
Product Support Specialist
