Can't see selection
Can't see selection
friesendrywall
Can't see selection
friesendrywall
Can anything be done with this? I find it frustrating when I can barely tell what is selected.
The problem got noticeably worse a couple months ago or so after some update.
innovatenate
Autodesk Support
Autodesk Support
You could hide the bodies in the browser to see the sketch profiles easier. You might also try a different environment to change the color scheme.
If that does not quite do it, you can look into editing the XML files for the color schemes.
I hope this helps.
Nathan Chandler
Principal Specialist
friesendrywall
I am looking at the XML, but there is a lot of undocumented stuff there, any idea what to change?
I am sort of afraid this isn't possible in the XML, as for all I know there are using the color and shading it internally.  I tried a couple of different environments, its not much different.
Am I really the only one who can't see what is selected good enough?
friesendrywall
It looks like changing
 <SketchProfileColor ARGB="0.15 1 0.55 0" />
to
 <SketchProfileColor ARGB="0.65 1 0.55 0" />
gets me what I want.  Really though, will this stick after an update?
These files got installed as read only for some reason, which I had to change.  They were located at C:\Users\Name\AppData\Local\Autodesk\webdeploy\production\7ca01d20fe2dafa65f944d9236f39fdec21b9b7a\Neutron\Server\Scene\Resources\Environments\
jeff_strater
This problem is being worked on right now.  The situation has been around for a while, but it was made worse by a recent change where non-active sketches were dimmed out a bit (to distinguish active from inactive sketch).
But, the point here is a good one, and we will improve the selection.
Jeff
Jeff Strater
Engineering Director
