Can't revolve one end of a solid body
hiCZ9ZX
Observer Observer
hiCZ9ZX
Observer
Observer
I created a lofted flange that was extruded from both directions. On the smaller end I created a sketch and projections for the circles and tried to rotate them into a 90° elbow. I've successfully created an elbow from just sketch lines, so I'm not sure why I can't here. I don't understand the error message:
"The profile crosses the revolve axis.  Trying moving the profile, or trimming it along the axis, so that there is no overlap."
Thanks.
TheCADWhisperer
@hiCZ9ZX
You are working too hard.
There is no need for a Workplane, second sketch or Loft.
Simple Revolve.
In most cases Loft should be reserved for "freeform" geometry.
Not how I would do this - but see Attached.
I have to run but will come back later with a couple of other techniques.
And watch out for this weak section...
hiCZ9ZX
Observer
Observer
That's great, thanks! Loft was the one thing I knew to do. I think I took care of the weak spot as well.
laughingcreek
incase your interested-
TheCADWhisperer
@hiCZ9ZX
I like the @laughingcreek solution, but back to your original question - what were you selecting as the logical axis of rotation?
See Attached.
TheCADWhisperer
@hiCZ9ZX
Before I saw @laughingcreek solution, something like Attached is how I would have modeled.
You can edit the bend radius as needed.
