Can't project all geometry
infoZGST4
infoZGST4
Hi everybody,
I just started out using Fusion 360 and I am really excited about the possibilities of this software.
I am running into an issue however with a bathroom vanity that I am drawing.
I try to maken in inside panel and I want to to project excisting geometry. Fusion however does not let met select the lines that I want.
Does anybody know why this is and how I can work around this?
Thanks in advance!
Lucas
g-andresen
Please share the file and tell us what you want to project.
File > export > save as f3d on local device  > attach it to the next post
günther
infoZGST4
Yes I am trying to upload the screencast but for some reason its not working.
Here is the f3d file. I am trying to project the black lines in the drawing. I can select the outer edges but not the inner ons.
I hope I am making sense. I am still trying to upload the screencast
g-andresen
1. activate "Slice" in the sketch palette > project the desired elements.
2. watch the screencast > project/intersect > select area >left click + hold > select edge from menu
günther
infoZGST4
Great! This solved my problem.
Thank you so much for showing me how to slice and how to use the intersect tool!
