Randomly I go to do a "Save As" and when the dialog comes up I am unable to open the folder I want. I end up just saving in ~master and then later moving the drawings or part. It doesn't matter if I close and re-open the save as command at that time, if it is happening it won't work. This doesn't happen every time but I would say it happens 20% of the time I try to Save As.
I have never seen it do this...
@innovatenate can you check this out?
Phil Procario Jr.
Owner, Laser & CNC Creations
May be related (or not), but is also annoying....This happens even more frequently than not being able to open any folder, nothing appears in the Move dialog....Usually, I end up going to A360 web-based browser and moving things. But sometimes I come back later and the Move dialog works.
Some questions to help us narrow it down:
Also, if you see this again, I am wondering if the network speed might be also be a factor? If you wait does the dialog populate? If you can reproduce the issue, can you run Performance Monitor to see what might be interfering?
BTW: You can check your speed at www.speedtest.net.
