Can't open file - HELP
I finished a design but couldn't export an STL file. So I closed the program but after that can't open the file. I get an error message that reads "We cannot perform this operation. Fusion isn't able to open this design at the moment. Please try again later or contact us."
TheCADWhisperer
Are you on Mac OS or on a Windows OS?  If Windows - what version?
Thank you for the response. I'm on Windows 10 pro, version 20H2, Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz 3.60 GHz, 128GIG RAM. This is MSI GT70 Titan DT95G machine.
I was working on my file with no issues. Then tried to export an STL file but it failed. Tried many times but all failed. So I decided to close the program. After that the file won't open. I can open other files but not this one. After it fails to open I also see a message that says "reference is missing".
There are 72 versions of the file and I found out I can open up to version 59. Anything above that won't open. I remember that at version 60 I inserted another file into the project (insert into project). Maybe this is the cause? But that file is still around and hasn't been erased. So I don't know what the problem is.
TheCADWhisperer
Can you Attach version 59 and the file to be inserted here for testing?
You mean attach the file version 59 and also the file that won't open?
