can't open .dwg files on fusion 360 for mac
cant open a .dwg file in a fusion 360 for mac osx el capitan. what can i do?
innovatenate
Autodesk Support
Autodesk Support
Do you have access to any other file formats for this design (e.g. IGES, SAT, STP, DXF, SVG, etc...)? Can you share the DWG file?
Are you using the upload command in the data panel or in the Autodesk 360 Dashboard to upload the file?
Nathan Chandler
Principal Specialist
HughesTooling
With DWGs you need to upload to the cloud to have them translated, are you doing this and is it failing? Can you attach a sample file that doesn't upload.
Mark
Mark Hughes
Owner, Hughes Tooling
