Can't offset ( sketch or model ) - initially imported from DXF
After importing the DXF file I received from a client, I started to make a 3D model from it, to be able to make some toolpaths and to try to mill this part in steel.
I have attached also some photos to see what I'm trying to make as the 3D model, and where I have the offset problem.
It's about the Key shape lines in the midle of the model, that in the finished product needs to be a sharp blade, so the key shape line you see in the sketch is the exact center of the blade, I tried to offset to the exterior , 1.5mm, but it doesn't matter the value, I can't offset those lines no matter what
I wanted to make 2 offsets of that line, one on the interior, very small, just 0.5mm and one on the exterior which will be 1.5mm, after that I though to make a kind of chamfer to make the model sharp.
PS. Attached is the model I made from the DXF file I imported to fusion.
Any help is appreciated!
