Can't offset from an offset?
fritter63
Message 1 of 14
fritter63
I've noticed this in a couple drawings, not sure if it started with the latest update.
I'm unable to create an "offset" from a curve that itself was created as an offset.
Video below. Sure, I can offset from the original one, but I'd like to keep things relative the width of the feature.
Can't offset an offset
Replies (13)
Message 2 of 14
donsmac
Select the "offset' constraint and delete it. Now you can do the offset.
Message 3 of 14
Hi, just checking if I understand this.
If I want to do a whole chain of offsets, each one following on from the previous one, I have to delete the offset constraint each time?
In other words, each offset curve requires the following:-
     ckick on the offset constraint
     right click
     click delete
     click sketch
     click offset
     click the curve to offset
     drag the curve to the correct side
     enter the offset distance
     hit enter
repeat as required.
Does no-one think this is a bit longwinded?
Brett
Message 4 of 14
donsmac
Hi Bret,
   I just discovered that when using the 'offset', if you type in an amount for an offset, that value stays with the dialogue box the next time you use it.
So instead of deleting the constraint and offseting the line you could simply offset the original line again and again by typing '+4', for example or whatever amount you want. That resulting value will show in the dialogue the next time you use offset.
 Using the 'offset' arrow is different. It doesn't affect the value that appears in the dialogue the next time you use it. The dialogue keeps the last number typed into it.
Doing the offsets this way allows you to edit the original curve and have the offsets update. Can't do that if you delete the constraints.
~Don
Message 5 of 14
HughesTooling
Here's another option offset from the original curve and use the parameter from the first offset + the offset you want from the first offset curve. So the first offset is d1, to offset 3mm from that curve add d1 to the 3mm. Both offset remain parametric done this way.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 6 of 14
LMD001
Hi Brett,
Reply from Autodesk: http://forums.autodesk.com/t5/design-validate-document/offset/td-p/6004105
Yep, that is probably the Parametric "price" to pay. Maybe the Offset Command will develop further in the future.
Offsetting the original curve to the needed multiple offsets is not all too difficult.
For me it is more important that the Offset command is parametric, I prefer not loosing the association and parameter, but that's personal and depends on the model I guess.
Best regards,
Ludo
Message 7 of 14
HughesTooling
Just to add to my previous post to get the parameter just hover the mouse pointer over the dimension for a second and it's displayed.
Mark
Mark Hughes
Message 8 of 14
LMD001
Hi Mark,
Tried this yesterday and it works OK, only, you cannot select a dimension, you can only type the dimension name, so you need to know the name. Not too big of a deal but not consistent with other commands where you can select a dimension as input.
Best regards,
Ludo
Message 9 of 14
HughesTooling
Hi Ludo
That problem does come up in some other places as well, you can only pick a dimension as an input while adding a dimension. For example when setting up a pattern you can't select a dimension as an input for the distance.
Mark Hughes
Message 10 of 14
LMD001
Hi Mark,
Yes, you are absolutely right, thanks for clarifying that.
- Ludo
Message 11 of 14
Ok,
Thanks for the comments and the help.
Brett
Message 12 of 14
jeff_strater
Yes, this is a known limitation of offset, and a tradeoff we had to make along the way.  I won't go into the details, but it is complex once you start doing offsets-of-offsets-of-offsets...
We do hope to improve this over time, but it is unfortunately a large project.  So, we made a decision that there was enough value in a fully associative offset, even with this limitation, to justify releasing it.  In the meantime, as @HughesTooling suggests, just keep going back to the original.  The result is the same.
Thanks for the valuable discussion
Jeff Strater (Fusion development)
Jeff Strater
Engineering Director
Message 13 of 14
gdolbier
Bump. I am finding I need this as well. Trying to make a stairstep circular pattern, circular pattern within circular pattern. Maintaining distance along the entire length of curve, not perpendicular to each point on the curve. but maintaining length along a tangent that points to the center of the curve, well over a dozen times. I'd be happy to provide example project, and example products that use this feature
Message 14 of 14
g-andresen
Share the file and name the elements, and their desired assignment.
günther
