Can't Log In
Can't Log In
Audymatic
Can't Log In
Audymatic
When I type in my login info into the login dialog box it just refreshes and does nothing.
There is no error it just reloads and clears the form fields.
If I try a user/pass that I know is incorrect it does give an error so it's not that I'm using incorrect credentials.
My login info is correct, I'm able to login to my account on the website just fine.
I've uninstalled and reinstalled, restarted, disabled my firewall, etc., and nothing works.
kris_berg
Hi @Audymatic ,
I am sorry you are encountering this issue.  I am looking into your issue and will get back to you as soon as I have more information.
Thank you,
Kris Berg
Fusion 360 Development
Kris Berg
Senior Software Architect - Autodesk
kris_berg
Hi Audymatic,
We have analyzed your logs and believe the issue is either related to a firewall or proxy server.  I am hoping this article here might help you  http://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Netw...
One way to verify this it to try and use your account while you are connected to a different network.
Let me know if there is more I can do to help you.
Thank you,
Kris Berg
Kris Berg
Audymatic
Actually I think it's something wrong with the software.
My system firewall configuration has not changed since I last used Fusion 360 without issue and I do not use a proxy server.
I installed the Mac App Store version, it logged in and is working just fine.
bob_holland
Autodesk Support
Autodesk Support
@Audymatic,
Thank you for the update and we are glad to hear that you are back up and running.
Bob Holland
Autodesk Product Support
