Not sure why it doesn't work on this one. What am I missing ?
Solved by davebYYPCU. Go to Solution.
Loft requires at least 2 profiles, the second one in your case is a point.
If you are lofting to a point then the rails have to be selected independently, Un tick the Chain select.
Don't like the airfoil, too many bumps.
Might help......
