Can't input dimensions inside "Edit Title Block" workspace
4 REPLIES 4
timon475
406 Views, 4 Replies
Is there a reason I can't input dimensions myself for the lines inside Edit Title Block workspace? Have you really forgot to input such a basic function? Do I really have to download AutoCAD to be able to create simple title block as a normal human being? Or am I stupid?
4 REPLIES 4
jhackney1972
in reply to: timon475
You seem to be frustrated by a big oversight in Fusion 360 drawing template creation.  I have a solution for you and you do not have to download AutoCAD.  Take a look at my blog article and included video, it is just what you need.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
timon475
in reply to: jhackney1972
That's a really nice work-around, thank you!
But this is still a workaround for a very basic function that shoud just be there from the start. I hope community/product manager would notice this post and add this issue to their's to-do list
jhackney1972
I can see on my end that this topic has been elevated so it may be considered in the future.  If you feel you have your solution, please mark your post as solved so others can find the solution if they have a similar problem.
John Hackney
Retired
Hey @timon475 : I already did it with the free 30 days trial version but didn't worked as expected.
One of the main issues I found was the XREF's from AutoCAD are not compatible with Fusion 360. That being said, it's a totally waste of time try to create the title block in AutoCAD and then importing to Fusion 360.
Technology Administrators
