can't import igus product files
I can open this file in a 360 and rhino but can't open it in fusion it fails . anyone know why ?
thank you
O.Tan
That's odd, I didn't have such issue opening the attached file.
Anyway, attached is the .f3d file, so you can continue your work if the imported file still fail to open after the Dec 10 Update.
Omar Tan
Malaysia
Mac Pro (Late 2013) | 3.7 GHz Quad-Core Intel Xeon E5 | 12GB 1.8 GHz DDR3 ECC | Dual 2GB AMD FirePro D300
MacBook Pro 15" (Late 2016) | 2.6 GHz Quad-Core Intel Core i7 | 16GB 2.1 GHz LPDDR3 | 4GB AMD RadeonPro 460
macOS Sierra, Windows 10
tomae
FWIW, I too can open it, no problem.
-Tom
NicolasXu
Hi Tony,
Thanks for reaching out to us. I tried the attached .stp file and it can be opened in Fusion 360 successfully. I'm using the latest update - 2.0.1768. Could you check it again on your side?
Here is a screencast to show my steps - both upload to cloud and open from local. If you can see the problem, could you share more information the problem you met? Thanks!
Best Regards,
Nicolas Xu
Sr. SQA Eng.
Fusion 360 Quality Assurance Team
Autodesk, Inc.
NicolasXu
Oops, didn't refresh the page before hitting Post button. Great to know it works!
Nicolas Xu
Sr. SQA Eng.
Autodesk, Inc.
Thank you for the replies , I am not sure why lt didn't want to work last night but this morning it did work .
