Can't get Intersection Curve to work
- Mute
- Permalink
- Report
The subject says it all. I have this example of my efforts:
I've tried everything I can think of (including using Patch to extrude the outer plan (XY) curve into a face and projecting the lateral curve to it), but everything results in a
Project to surface failed, please check the surface or the vector!
message, which means nothing to me.
This seems to be a relatively rare topic in the forum. I did find the exchange and screencast from back in February, but this did not provide enlightenment.
Invoking the Intersection Curve command before starting the sketch didn't seem to make a difference and, even if it did, it would result in an awful lot of sketches because I want to intersect the entire lateral elevation curve against both of the plan curves (and in my real application, considerably more).
Also, I don't see how my example differs significantly from the screencast except in complexity, and then not really by that much. Is there something in the screencast I am missing?
Additionally, is there some way to get the command to accept multiple curve segments for the first input to the command? I tried holding down the Ctrl key per something I read in that February exchange, but that didn't work. Ultimately I want to intersect the whole lateral curve with both plan curves so that I end up with two rail curves for a Loft operation. It is not clear to me that a bunch of curve segments that happen to end and begin at the same point will be accepted by the Loft command as a single, continuous rail.
This is not a rush item, so there is no need to drop everything to answer right away. Also, if I'm not doing the public link right, somebody please let me know how this is done.
Bill
