Can't fully constrain a sketch
axel.dumas.kct
Message 1 of 10
axel.dumas.kct
Hello !
It's my first post on your forum and I am relatively new on Fusion 360.
I mainly use Fusion 360 to make holes in aluminium plates and electrical boxes.
On an other project, I wanted to create a SUB-D (https://fr.wikipedia.org/wiki/D-sub) hole.
In my little project, I am nearly sure that my sketch is fully constrained.
I wanted to set one circle at the same distance from the square than the other. So I use "=" canstraint.
But it doesn't show a my circles in black.
 I have to put a hard value myself to get it black (the 7mm).
It's very disturbing to have blue lines when I think it should be all black.
Do you have an idea on the "problem" ?
If you need more informations, doesn't hesitate to ask me.
Thanks a lot for your help,
Sincerley.
Replies (9)
Message 2 of 10
hamid.sh.
@axel.dumas.kct wrote:
... I wanted to set one circle at the same distance from the square than the other. So I use "=" canstraint.
Your thinking is correct and what you described above must fully constrain this sketch, if done correctly. I did it:
I wonder where is the problem. Could you export your file to *.f3d and attach it here so I can take a look?
Hamid
Message 3 of 10
axel.dumas.kct
Hello @hamid.sh., thanks a lot for your help !
Oh, that's good ! And surprising.
Yes, I send you the file.
Sincerely.
Message 4 of 10
dsouzasujay
Hi @axel.dumas.kct
The more you use Constraints the less you can use the Dimensions
I have created a screencast video to explain how we can use Constraints in a sketch to define symmetry.
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 5 of 10
axel.dumas.kct
Hello @dsouzasujay, thanks for your help.
Yes, I understand that.
Where can I find your ScreenCast video ?
EDIT : I have just found that when I do a line from the square to the circles, and then I apply "=" constraint, it fully constrain my skecth.
However, if I start from circles to the square, it seems it doesn't works.
Is there a real difference ?
Message 6 of 10
dsouzasujay
Hi @axel.dumas.kct
There are lot of ways we can constrain a sketch geometry, it all depends on the type of sketch we are constraining.
You can refer below video (The one i have missed to add in the last post)
https://autode.sk/3u9uuoA
We can also use mirror the hole along the center construction line.
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 7 of 10
hamid.sh.
@dsouzasujay This looks like a bug. When I draw construction lines starting from circles' center I can't make it fully constrained. But when I start from the rectangle I can. Here is a screencast.
Hamid
Message 8 of 10
axel.dumas.kct
Oh...I should learn to create ScreenCast too. ^^'
@dsouzasujay No problem for your link.
It's interesting. I haven't used yet symetry on Fusion 360.
My problem is exactly the one shown by @hamid.sh.
Message 9 of 10
dsouzasujay
@axel.dumas.kct  Thanks for reporting this issue!
@hamid.sh. for the explaining clearly with a video
I agree with you that this is a bug, But we do have other workaround for this workflow, reported as FUS-102353 in internal issue tracking system. Hope we get it resolve sooner. Thanks!
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 10 of 10
axel.dumas.kct
No problem @dsouzasujay.
Especially, thank you both for your very useful help and your explanations.
Sincerely.
PS : Thanks you for making Fusion 360.
