Can't find the Shell command
gillesht
gillesht
I'm using Fusion 360 1.8.679 and can't find the Shell command. Where is that command?
Best regards.
AndrewSears
Are you in the model workspace?
Andy
Oceanconcepts
I will also add that, if you are in the Sculpt workspace and dealing with a T-spline body, the thicken command can be useful for creating shells.  It sometimes succeeds with difficult shapes that Shell can't handle.
- Ron
Mostly Mac- currently M1 MacBook Pro
gillesht
No I was in the Sculpt model. I'll change my model workspace and try it out. Also how can I export my model in geomtry exchange format as DWG, STEP, IGES?
Best regards.
AndrewSears
- Click on "details" for the file you want to export.
- When the details page comes up you will see "Export" and choose the file type
- The export process will start so now you can go back to the dashboard.
- When the export process is done you will get a notice in the activity feed showing you the exported file and a PDF summary of the translation report.
- Under the file you just exported, you will see "Download" to save the file where you want.
The abbreviated version:
-Click details
-Select Export
-At dashboard click download
Let me know if you have any problems with this.
In the future, can you start new topics with a new post?  This will make it easier for other customers to find the correct information.
Andy
gillesht
I finally created a solid using the SHELL command in the MODEL workspace. I've used HOLE to makes a hole in the model. I've exported the model to an .stl format. The result shows a surface on the larger face of the model. Why? That model is hollow. I've attached the .stl file.
Best regards.
