Can't delete certain constraints
timF4ETD
timF4ETD
Constraint: box corner - to - box corner
Can't break the smaller box free, without breaking line constraints.
Only 3 constrains appear.
I tried deleting 1 at a time.
Long press on point, only shows 1 "sketch point" option.
Right clicking - delete coincident, deletes all 3 coincident points
jhackney1972
Please attach your model for help.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it. If needed, ZIP a F3Z file.
John Hackney, Retired
timF4ETD
Just draw 2 squares and constrain 1 of the corners... it'll be faster than downloading and opening my file
TheCADWhisperer
@timF4ETD
Just delete the coincident constraints, click and drag the lines and reapply coincident constraints (or window delete the smaller rectangle).
Would be fast.
timF4ETD
It's what I've been doing, but it's time consuming and breaks other constraints and features (like rect. pattern).
I figure there's a better way.
jeff_strater
The "problem" here, if there is one, is that Fusion tries, whenever it can to combine points.  It tries to avoid a "point stack" in most cases.  You can see here that there is just one point with 4 connected lines:
I'm not sure why there are only 3 coincident constraints shown (there should be 4, I believe, one for each line connected to this point).  Fusion does not recognize this as a rectangle, just 4 lines connected together with constraints between those lines.  When you create the second rectangle, picking the point of one rectangle as one of the new rectangle points, Fusion just reuses that point as one of the points in the new rectangle, and connects the new lines to it, just the same as if you create one line, then restart the line command, picking one endpoint of the first line.
I understand that this is not what you are expecting, but I'm just describing the way it works.  The short answer is there is no way to decouple these when they are created this way.
To make things more confusing, point merging is not done with the point-to-point coincident constraint.  It does leave the point stack in place.  And, then, you can decouple them, though it is trial and error to figure out which one to delete:
Jeff Strater
Engineering Director
jhackney1972
You wrote "And, then, you can decouple them, though it is trial and error to figure out which one to delete:"  I have found if I select a Coincident Sketch Constraint, at least on a fully constrained model, the entities affected by the coincident constraint are highlighted so it is not entirely guesswork.  It is not an easy process but I use it from time to time.
