- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
OK. I'm drawing a deck.
I first made my sketches and then extruded the different parts of the building, concrete slab outside the door, and wall/window features.
I extruded the *perimeter* decking boards as individual Bodies.
I then created a new sketch on the edge plane of one of the perimeter boards.
I then needed to extrude the sketched inner decking boards to the other side, ending at the far perimeter board.
BUT-
There is an area where the perimeter comes inside the main rectangle shape of the deck.
So, I extruded the inner planks all the way across this obstacle, and used the deck perimeter sketch to extrude>REMOVE the inner boards, creating new Bodies.
This left Bodies that are in this sort of pattern:
________ ___ ________
_____________________
I can select and move, rotate, stretch ... whatever I want to them, but I can't delete them.
When I select those small Bodies and try to delete them, I get this message:
"This feature is referenced by other features in the timeline. Are you sure you want to delete?"
If I actually click to delete the selected bodies, the ENTIRE ROW of decking vanishes!!!! (Not just the chunk I had selected.)
Can I somehow tell Fusion to just delete those small chunks of deck? In other words - can I tell Fusion to CHANGE the 'references' to some other stuff?
If Fusion has created the "Body" entity, can't I get it to make all the Bodies independent?
AAARgh. SO many hours of work got me here, and now THIS is making it all worthless?
Please help...
