Can't chamfer edges
Can't chamfer edges
Can't chamfer edges
I am brand new to Fusion 360.  I am trying to chamfer the edges of this cylinder.  It is allowing the chamfer angle relative to the OD of the part as I want on the one side, but it is creating the chamfer relative to the face on the opposite side.  What do I need to do to control which relative surface I want to chamfer.
jhackney1972
I hope I am understanding your question, if not please try to explain what you desire and the forum can surely help.  Next time you post a forum question about a particular model, you should attach your model for two main reasons.  The person who responds can answer the question on YOUR model making it a more relevant answer and also your model may have conditions that affect the answer.  Take a look at the Screencast and see it satisfies you need.
If you do not know now to attach a model, simply open it in Fusion 360 and the select File, Export to your hard drive.  Then using the Attachments section below to attach it to your question.
John Hackney, Retired
That was exactly what I was looking for. You explained my question better than I did. Thanks also for the tip on posting the model.
