Can Rifling be done in Fusion 360? with IMAGE Reference
Hi, does anyone know how to model a Rifling in a barrel in Fusion 360? is it even possible?
I have tried many methods but all seem to fail..
this is what I need:
Image result for rifling barrel
davebYYPCU
Use Create > Coil, Sq section, sizes to suit you details, to make one,
then use Create Circulate Pattern for the others.
If this leave you just as stuck, will need some sizes to go with.
Lenght of barell, how many lands, depth of groove, and how many turns the one land makes from one end to the other.
Might help...
davebYYPCU
Well that doesnt work as expected,  coil is used for the sweep, but did not make the land as I thought it would.
But got one done with the coil producing the guide rail, for the sweep.
Example attached,
