Can not select a body when using the shell command
9 REPLIES 9
Message 1 of 10
njdodson87
441 Views, 9 Replies
I am having an issue SELECTING a body to shell.  The body was created using SURFACE LOFTing and MIRRORing that shape.  I don't know if the surface lofting is the problem.
I could not get the loft to work using the "SOLID LOFT"
Tags (1)
Labels (1)
9 REPLIES 9
Message 2 of 10
davebYYPCU
in reply to: njdodson87
Shell is for solid bodies.
Use Thicken.
Might help....
Message 3 of 10
g-andresen
Please share the file.
File > export > save as f3d on local drive  > attach it to the next post
günther
Message 4 of 10
njdodson87
in reply to: g-andresen
I can not add the file (work related) but have attached a screen shot of said model.
I want to thicken the hull to .5in...
Message 5 of 10
njdodson87
Sorry, forgot to include the error,
"The operation could not create a valid result. Try adjusting the values or changing the inputs."
Message 6 of 10
g-andresen
The picture does not allow any conclusions about the development of the object and therefore only the crystal ball helps here.
günther
Message 7 of 10
laughingcreek
you most likely surface quality issues.  happens a lot when lofting to a singularity.
Message 8 of 10
njdodson87
in reply to: laughingcreek
Can you explain on this? Singularity?
Message 9 of 10
You would probably get better results "overbuilding" surfaces and then trimming back.
https://www.youtube.com/watch?v=1rMxcK_No-A&list=PLp5izJt_zvN0GnwEUFR1zE06nQvDAWxz2&index=1
However, for a last ditch effort on what you already have - I would Patch the top. Stitch to a Solid and see if would Shell removing the top.
Message 10 of 10
laughingcreek
I just mean lofting to a point.  fusion allows it, but it will frequently cause the surface to be wonky, which can cause subsequent actions on the surface fail.  lofts perform best when they are 4 sided. when 1 side is a point, it bunches up into the point.
