- Mute
- Permalink
- Report
I'd like to create a complex lofted surface and how I visualise I'd be able to do it is create a kind of spline cage. I'm pretty sure this would work but I can't work out how to actually create the rails between the two profiles? Since you can only create splines on a plane, as far as I know, how would I connect my rails to the profiles points?
I've created the two main profiles on two differently elevated planes. I now need to create the 3 rails as show in the image. Could some tell me how I would go about doing this? Is it possible? I've attached some images to explain and the scene file.
Any help much appreciated.
