- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello to all,
I have looked for a solution in past messages seeking help with circular patterns. There are none that seem to relate to my issue. I have come from a shop floor environment where bolt circles are a common issue. I have tried the circular pattern guidelines. They work for machined pockets, plain circles, and center points. When I create a 3/8-16 threaded hole, using a .313" tap drill .75" deep, with threads .38" deep everything is fine. When I try to create five copies around a 5.0" dia. circle, the icon for creating a circular pattern is not darkened or capable of doing anything. In a post about two years ago, this did not seem to be a hot issue as far as the development group was concerned. Has this changed?
Can someone shed some light on either my inexperience with the product, or a way to do these features short of recreating each hole over at each point. My take from what I have read and observed, is that a circular pattern only works on two dimensional geometry.
Thank you and best regards,
Bob Queberg
