Can anyone help me create a cutting edge to this cookie cutter?
I am new to Fusion 360 and would love help adding a cutting line to this cookie cutter. It printed well, but it is not sharp enough and I'm not sure how to do this in Fusion. Thank you for your support.
davebYYPCU
Not that file.
In the Fusion file, chamfer the outside edge with the chamfer angle you wish to use.
Might help....
TrippyLighting
Please share the native Fusion 360 file (.f3d format).
.stl files are triangulated mesh files that work fine as output to a 3D printer, but they don't serve well as input to a design process 😉
As @davebYYPCU has already mentioned, you might try the chamfer function and see if that provides you with what you need.
Yes so sorry, uploaded the wrong file! The f3d is attached. Thanks!
TrippyLighting
Have you tried the "modify->Chamfer" ?
What did you observe ?
TheCADWhisperer
See attached for possible "solution".
