Camera Example
Camera Example
ojblaster
Camera Example
ojblaster
I am very new to fusion, how can I extrude these as two different faces (one goes furthur out than the other one)
Drewpan
I would strongly recommend that you do the embedded tutorials in the Fusion Documentation and also some of the
Self-Paced Learning to help you to learn fusion faster and better. They can be found here:
It is also much easier for the forum to help you if you attach your file AND a screenshot of what you want to achieve
and what the problem is. You can create a file to export like this:
Time spent on the tutorials and self paced learning will not be wasted. Also check out the three RULES that are pinned to the forum for further guidance.
Ok - how do you extrude this?
You can only extrude a closed shape and these turn pale blue inside which is what you have.
Go to Extrude on the menu or hit E.
Select the first area to extrude.
The solid is created but the sketch will be hidden, so turn visibility back on in the browser tree - the Eye icon.
Hit E and extrude again the section of the sketch you want.
Make sure the operation is set to Join.
There is your camera shape.
Cheers
Andrew
