cam under geometry , using selection not selecting the pockets properly. help
830403205
830403205
in fact all pocket types not working correctly
using nk105 control by weihong, choosing weihong nc studio post processor
thanks all
etfrench
Why were the bodies rotated 90 degrees?  It's not necessary for Manufacturing.  It's also not necessary to move the lid.
Simulation shows all of the toolpaths are machined correctly.  What do  you believe is wrong?
p.s. What is the purpose of the toolpath, 2D Contour1 4mm f, in Setup3?
ETFrench
Make toolpath using selection under geometry.
u will not be able to select the whole of the pen , leaves 2 gaps.
thanks
etfrench
Can you make a screencast of the issue?
ETFrench
