CAM G Code issue
CAM G Code issue
hato54
Message 1 of 9
CAM G Code issue
hato54
I start with a Face milling but the Face mill will first go to Z0, then travel to the start point.
Then it goes to Z15 (Clearence), then Z5 (Feed) and last Z-0.5 (the milling level) which is ok.
Why will it start Z0, it should be Z15 (Clearence)before it travels to start point?
I must done some wrong????
Need help.
(1001)
(TEST1)
(T3 D=52. CR=0. - ZMIN=-0.5 - FACE MILL)
(T7 D=6. CR=0. - ZMIN=-15.5 - FLAT END MILL)
(T8 D=5. CR=0. TAPER=118DEG - ZMIN=-17.5 - DRILL)
G90 G94 G91.1 G40 G49 G17
G21
G28 G91 Z0.
G90
(FACE1)
M5
M9
T3 M6
S1000 M3
G54
M8
G0 X103.8 Y-36.106
G43 Z15. H3
Z5.
G1 Z4.7 F300.
G18 G3 X98.6 Z-0.5 R5.2
G1 X70.
X0. F1000............
Best regards
Håkan
Replies (8)
Message 2 of 9
HughesTooling
I think this might be set in the post-processor, what post are you using.
Mark.
Mark Hughes
Owner, Hughes Tooling
Message 3 of 9
HughesTooling
Looking at your code a bit more the G91 sets incremental mode so the z0 should not do anything.
Mark.
Mark Hughes
Message 4 of 9
Have you tried running it yet, or are you just reading your gcode?
G28 is an interesting function that I've never used before. http://www.cnccookbook.com/CCCNCGCodeG28ReturntoReference.htm
I don't know why your machine would go to Z0 when it's calling a Z0 move using relative coordinates (G91).
Message 5 of 9
hato54
I test the code without starting the machine (using Mach 3) and it really moves the spindle to Z0.
/Håkan
Message 6 of 9
hato54
I will go to my shop and test it in the real world and see what happens...
Message 7 of 9
HughesTooling
G28 is listed as return to home for Mach3, so is your machine fitted with limit switches. I think Mach3 has machine coordinates and part coordinates it should be going to the machine home.
Mark
Mark Hughes
Message 8 of 9
It is but I believe if you feed it a coordinate it goes to that location before returning to home, but in this case the coordinate is a relative Z0 so I'm not sure why it's moving anywhere other than machine home. Perhaps his machine home on Z is 0 and low on the Z travel. I always setup my machines so the top of Z travel is 0 and the rest is negative to avoid these sorts of mistakes.
Message 9 of 9
hato54
Now a made the final test on the machine.
First I pushed the button "Ref all home" and then I jogged X, Y in the center of my vise and Z down and zero.
Then I started the machine...
It works just as You say Mark, the machine return to Z home, not Z0.
When a tested the code in the Mach 3 software (no machine was connected to this laptop) the Z moved to the Z0.
I think I have to simulate a "Ref all home" if I should make a "software" milling.
Thank You all for helping me
Best regards
/Håkan
