Cam and Follower Problem
mikeYEAME
mikeYEAME
I want to animate this Cam and follower set in order to analyse the gradients/forces exerted on the cam follower. The cam shape is derived from two splines and two arcs. I am using a sliding joint on the follower, revolute joint on the cam and the guide pins are grounded. I have a contact set between the cam and follower. As can be seen from the screencast the cam rotates until it reaches the spline, stops and then skips over to the next arc. It rotates a couple of times and then collapses. Is there a way to improve this or is it too much computationally?
rgs Mike
Marco.Takx
Hi @mikeYEAME,
Please place your question on the Fusion 360 Design, Validate & Document forum.
This is the Fusion 360 Computer Aided Machining (CAM) forum.
If my post answers your question Please use  Mark Solutions!.Accept as Solution & Give Kudos!Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
mikeYEAME
rgs Mike
JDMather
@mikeYEAME wrote:
... in order to analyse the gradients/forces exerted on the cam follower.
Do you have access to Autodesk Inventor Professional with Dynamic Simulation?
(Students can download Inventor for free from http://www.autodesk.com/edcommunity )
Can you File>Export and then Attach your *.f3d file here?
TrippyLighting
The problem is that a CAM follower would require a specific joint n Fusion 360 to be created efficiently.
The only workaround is to use contact sets.
The problem with that is that contact sets are an incredible resource hog and in this case it seems that the animation module does not wait for the contact sets to finish their calculation and thus it looks like it skips.
Unfortunately I don't have a good answer how to tackle this.
sanket223.patil
Contact sets is only you can use here , when you click on animate joint it is going to skip the main step . Manually by dragging it will work .   Once i working a cam , it was skiping  when the cam touches the push rod.
Can you share the file .
Sanket Patil
Mechanical Engineering
Expert Elite
chrisplyler
1. Need a revolve joint for the cam, of course.
2. Need a slider joint for the follower, lined up in the right direction, with max and min limits representing the high point of the cam and the low point of the cam, with the rest position at the low point value. This gives the spring action down to the low point.
3. Need a contact set between the cam and the follower, of course.
