Creating custom size drawing sheets
I have a drawing size of 86 inches. But the maximum available drawing sheet dimension is of about 44 inches. I need 1:1 ratio of drawing sheet for Laser cutting purpose. How can I create Drawing sheet of required size in Fusion or in Autocad?
Marco.Takx
Hi @Anonymous,
Currently, Fusion 360 Drawing doesn't support sheet size customization. One workaround is to output the DWG file and then use AutoCAD to modify the sheet size and print out format such as PDF. I understand using a more application makes the whole workflow not that smooth.
If my post answers your question Please use  Mark Solutions!.Accept as Solution & Give Kudos!Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
Hi. Even in Autocad the maximum available size is 36 in x 44 in . I need 86in x 43in. Can this be possible? If so please help me out.
Marco.Takx
Hi @Anonymous,
https://www.youtube.com/watch?v=xehYIjcFQNw
Marco Takx
jeff.whitney
Community Visitor
Community Visitor
That depends on your printer/plotter.  I have often created a custom size for long prints such as yours.  Go to your printer properties and see if there is a Custom 1, Custom 2, etc.  Modify one of those to your needs.  You will need to save the PMP file and make it current for your printer.
