Cam and Follower mechanism randomly gets stuck using barrel cam
1076361
1076361
I was building this cam and follower mechanism for a school project, and I wanted to add a barrel cam to introduce horizontal movement. At first I tried a normal hexagon cam and achieved proper movement with a slider joint and a tangent relationship. Then I tried to create the relationship for the barrel cam. I did the same thing, but instead of a vertical slider joint I made it move on the X-axis. Then I also added the tangent relationship. Whenever I try to move the cam, the first rotations go smoothly and work as expected. The problem is when I release the handle at a certain position the mechanism always gets stuck (the handle, cams, followers), and I have to use ctrl + b to reset everything back to its original position. I wanted to know why the mechanism was getting stuck, and any possible solutions. I have attached the file here. Any help would greatly be appreciated!
TheCADWhisperer
@1076361
See this discussion. Your cylindrical cam is not modeled correctly.
Solved: I need help ASAP with making a cylindrical cam - Autodesk Community
@TheCADWhisperer Thank you so much! Your video helped me solve the issue!
lauri_barnhart
Hi @1076361, thank you for your question.
Did the response provided by @TheCADWhisperer help answer your question?
If yes, feel free to click on the Accept Solution button.
This helps other users benefit from the information.
In case you still need help, please provide an update here so we can help you best moving forward.
Best,
Lauri | Community Manager
