Cam Addin
Cam Addin
wtxrcdog
Message 1 of 12
Cam Addin
wtxrcdog
 I keep getting a message cam addin can't load so I have no cam.
  Thanks Bruce
Replies (11)
Message 2 of 12
jeff.pek
Hi Bruce -
Sorry you're having problems. Have you done an update of Fusion recently?
One thing we've recommended when people run into problems like this is to try a clean reinstall.
Can you see if this can help?
Best,
  Jeff
Message 3 of 12
wtxrcdog
I tried a clean reinstall and had the same outcome I am going to try another computer.
Thanks Bruce
Sent from my iPad
Message 4 of 12
bob_holland
Autodesk Support
Autodesk Support
Bruce,
Can you please clear your user cache data and then let me know of your results:
Thank you.
Bob Holland
Autodesk Product Support
Message 5 of 12
wtxrcdog
 Hello
 This did not help. The cam addin has never loaded on this computer ever. I did install on another laptop and it works but this is the laptop I really need it on.
  Thanks Bruce
Message 6 of 12
bob_holland
Autodesk Support
Autodesk Support
Bruce,
Can you please send me you Diagnostic Log Files:
I would like to take a look and see if there may be a clue as to what might be going on.
Thank you.
Bob Holland
Message 7 of 12
wtxrcdog
A good attitude won't solve all of your problems but it will annoy enough
people to make it worth your while!
Message 8 of 12
bob_holland
Autodesk Support
Autodesk Support
Bruce,
Can you please send the ZIP of your log files to:
bob dot holland at autodesk dot com
Thank you.
Bob Holland
Message 9 of 12
wtxrcdog
Sorry I tried to send it last night. I will try again.
Message 10 of 12
bob_holland
Autodesk Support
Autodesk Support
wtxrcdog,
I am sorry but I do not seem to have received any emails from you.
Please try sending a text only email to see if I receive it to:
Thank you.
Bob Holland
Message 11 of 12
jeff.pek
Hi -
We are now suspecting that this problem is due to an anti-virus package (perhaps webroot?) moving one of the CAM-related files (post.dll) into a quarantine area.
Could this be the case on your system?
If this is what has happened, if you restore this file, then that should fix it.
Jeff
Message 12 of 12
wtxrcdog
 The webroot security software was the problem.
Thanks for your help
Bruce
