calculation with parameters went wrong
fong1980Y8EU2
fong1980Y8EU2
Hi Everyone,
I try to multiply a value to a parametric value.
it only works with plus or mines, but when I want to multiply the values. then they give me the red numbers and tell me, it impossible to multiply the two numbers.
g-andresen
If number is to represent a quantity, "no unit" must be set for units!
günther
shahriarsifat1802164
You can check these discussion.
https://forums.autodesk.com/t5/fusion-360-support/unable-to-multiply-or-subtract-with-parameters/td-...
thank you.
Md. Shahriar Mohtasim
Dept. of Mechanical Engineering,
RUET
LinkedIn | Facebook | Youtube (CADs) | Twitter
Autodesk Product Users, BD
If you found this post helpful please hit the LIKE button and for a solution hit the ACCEPT SOLUTION.
Thank you.
