CAD an arm cast with connecting points
kskelil
kskelil
I am fairly new to Fusion 360 and CAD in general. I am working in an orthopedic office, and we are attempting to 3D print an arm cast in the "voronoi" design. I have used meshmixer and fusion 360 to get the cast and design down (I have attached the 3D scan of the arm we used, the cast, and the voronoi inspiration).
I am having trouble separating the cast into two pieces and then having them connect. I don't know how to fill triangles in or to create a cut aside from a plane cut directly through the middle. How would I go about separating the cast into 2 halves that can be connected and disconnected for a patient to wear?
Thank you in advance!
-Kyle S
TrippyLighting
Tying to work with large .stl data sets in Fusion 360 is rarely a good idea.
Looking at the brace .stl is this the original scan ? It looks like someone has already meddled with the file and tried to close the open .stl.
If you want to work with Fusion 360 this needs to be converted from a triangulated mesh into a NURBS surface.
If you want to stick with mesh processing and Meshmixer: Two threads from the MM forum which may be interesting for you:
Creating various casts/splints for a 3d scanned right arm
How can i model/where can i find "male female connections"
TrippyLighting
@Anonymous Awesome stuff!
@TrippyLighting : You're welcome.
We need to close the gap between BReps and mesh representations. So whenever you feel an issue targeting mesh representations on your playground : Drop me a line....: I'll try to step into it.
kskelil
@Anonymous
Thank you so much! This is super helpful, you're awesome!
drew.regner
@Anonymous  I know its an older post, but thanks, this answered my questions I was asking about making casts.
