Bulk STEP Export?
Bulk STEP Export?
maruska
Bulk STEP Export?
maruska
Is there a way to bulk export Fusion 360 files to STEP? I have a project with 47 individual files and I'd like to dump them all to individual STEP files...
Cheers,
J.
bob_holland
Autodesk Support
Autodesk Support
maruska,
To answer your question, Fusion does not have a mechanism to perform a mass export.
Is this something that you typically do?
Thank you.
Bob Holland
Autodesk Product Support
San_Escobar
I am not sure if I got your question right, let assuming that you have a Fusion 360 assembly of 47 parts.
Whether you export it directly from Fusion or from Dashboard, It will generate one single STEP/STP file for sure.
However, what will determine numbers of parts within your STEP file will be the software that will open the file, for instance
Inventor, Solidworks and so on should have the same behaviour. One file (.STEP) 47 subparts on feature tree/ Browser.
just like if you have a asm. file without history.
But, a different walkaround is if you open it using Alias, then what you get is a single files with several groups, which can be
ungrouped, and grouped back as one piece. than exported as whatever kind of standard file you want.
HTH, happy modelling.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated.
Thanks!!!!
If this solved your issue please mark this posting "Accept as Solution". Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Happy
