Building a sheet metal box using a scan
kevanromero
kevanromero
I would like to create a sheet metal box using a 3D scan. The scan has many contours, and I want to make the box at an angle to the faces of the scan. When I create the sheet metal, the edges/profile protrude through the scan due to the thickness of the metal. It doesn't matter whether the sheet metal is created inside or outside of the body; there are areas that would physically intersect with the scan. I don't know how to tell the program to compensate for the thickness of the material. Am I even going about this the right way? Thank you.
johnsonshiue
Hi! I guess you might need to set a bigger Bend Radius but I am not sure. Please share the model here. It will help us understand the issue better.
Many thanks!
Software Test Engineer
