Building a fully parametric part help, inputing a dimension list
Apologize for not learning the fundamentals, but I don't have time and just came across this software. I have 2 days during this holiday vacation to put 3 hours into building a respectable fully parametric sample part to show a startup owner the ability of this software an myself. The guy understands the rush of this project, but I need to be able to show the changing of dimensions and re-building of the part based on how we proceed with R&D and prototyping.
My question is can I begin building a part in 360 by immediately opening a list somewhere where I can start typing in dimensions and naming them so I can just reference them while I am building the part or are you inputting the names and dimensions on the fly.  I'd really like to have a list I can input them all at once or better yet just upload an excel sheet.  If I can upload an excel sheet, I'll be real happy.
Appreciate the help.
jeff_strater
Hi @Anonymous,
Yes, you can pre-define parameters in the Change Parameters dialog:
I don't know if there is any way to import a spreadsheet to define the parameters, but this is something that could be done via the API (and, in fact, someone may have done this already, for all I know).
Good luck with your test!
Jeff
Jeff Strater
Engineering Director
HughesTooling
You can setup a list of parameters before you start.
See parameter dialog help
http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-76272551-3275-46C4-AE4D-10D58B408C20
There is a plugin for import from a spreadsheet.
https://apps.autodesk.com/FUSION/en/Detail/Index?id=1801418194626000805&appLang=en&os=Win64
Mark
Mark Hughes
Owner, Hughes Tooling
