Build plate not being created under part?
autumn.staub
autumn.staub
I'm hoping this is a simple fix. I've been using Fusion for ab out 3 weeks now but today, when I make new setups, my build plate isn't positioning itself below my selected parts but instead is going up and to the right of the part (see attached). I then have to move the part to sit atop the build plate, but each time I make a setup it's doing this behavior.
Any ideas? What have I done haha?
jhackney1972
You did not supply your model but I will take a guess.  My guess is that you did not model your component anywhere near the model origin.  Attach your model and let the Forum take a look.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section of a forum post to attach it.
John Hackney, Retired
