Thanks @rohit.bapat for bringing focus to this.
I came across it today in my work and like the creator of this post, wanted to check if it's a bug or not.
My intention (screencast below) is to model an arc based on structural optimization mesh. At the top of the arc needs to be a flat top bar.
1. I tried dimensioning between the top line and the conic curve. This isn't possible (if it had been, my need would have been fulfilled).
2. So I went for making an additional line (to the right; should be a construction line) and thought to make a tangential constraint between it and the conical curve. As you can see, the line drops down, and isn't actually tangential (though Fusion 360 claims so by having the tangential constraint icon attached).
Thanks for your words "Looking forward to working with you all and make Sketch more reliable". Consistent reliability and consistency of underlying features is terribly important and I appreciate you personally bringing light to this, within Autodesk.
Also, I feel the company could focus on more urgent delivery of fixes that have been taken in the ticketing system (i.e. confirmed and accepted to a roadmap). In addition to this, Curved Slider Joints (FUS-26127) was taken in around 3 years ago. If lack of being able to proceed with these is a business decision, please raise it up internally. No-one benefits from long turnaround times. Such fixes may not be fancy on slides, but they matter to everyday use!
Apple had this once. They made a whole Mac OS X release that was focused on stability and getting the underbelly right. Then they pushed on for more features. Be brave in pushing for the ticketing cleanup!
Asko Kauppi
IT guy into Cleantech.
