Bug (?) when making circular pattern with component
TrippyLighting
Consultant Consultant
TrippyLighting
I create a circuar pattern of three Socket Head Cap Screws (SHAC) and hte pattern is created fine but I can move te patterned screws out of place by dragging them with the mouse.
Here's ascreencast
jeff_strater
I'm pretty sure that component pattern has never forced the instances to stay in place (that is, cannot be dragged).  What component pattern does is to create the instances and place them, but not constrain them.  Then, like any other component, they can be further positioned.  When that happens, the "snapshot" UI appears in the toolbar, indicating that components have been moved.  If you add a Snapshot, then that new position will be captured.  But, if you do a Compute All, or Revert, the instances will go back to their original positions.
To make them stay, you would want an As-Built Joint just after the component pattern.  This will let you choose the type of joint that is created (revolute, fixed, etc).
Hope that is reasonably clear.
Jeff Strater (Fusion development)
Jeff Strater
Engineering Director
Very cool, did not know about patterning components...thanks guys!
Jesse
TrippyLighting
Thanks for quick feedback. I have to tinker around with this as it works different than I expected.
TrippyLighting
I've found a working solution in selecting all patterned components and applying a rigid group joint. If I then change the BCD (Bolt Circle Diameter) the patterned components follow nicely along.
However, I have an idea that I'll post in the idea to make that workflow a little more efficient for assembly purposes and  will post it later in the idea board.
