[BUG] Thicken Chain Selection doesn't work.
Beyondforce
Advisor Advisor
Beyondforce
Hey guys,
The Chain Select doesn't work:
Cheers / Ben
Check out my YouTube channel: Fusion 360: NewbiesPlus
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
HughesTooling
I was going to write, "Chain select only works if the surface join is a tangent or smooth" but I found if you select an edge it will select all joined surfaces. See screencast.
Mark
Mark Hughes
Owner, Hughes Tooling
Beyondforce
It's a nice Tip, but that's not what Chain's means 😉
It shouldn't matter where you click is should take everything. Else, they should change it to "Chain Select" but only if you click on an edge!
Ben Korez
| YouTube
