Bug: specifying a user parameter in an associative offset doesn't associate
sprior913
sprior913
After the new associative offset update if you specify a user parameter value when doing an associative offset in a sketch the value of the parameter will be used, but it doesn't stay associated with the parameter.  If you change the parameter the offset will not update.  However if you click on the offset dimension and replace the numeric value with a parameter name then it will stay associated and change as the parameter changes.
FrankCao
Hi sprior913,
Thanks for reporting this issue. This is a good finding that we lose parameter association during sketch offset forward creation.
We have logged FUS-22394 internally to track this problem and have sent this issue to our development team to take a look.
Frank
This is still occurring, I still have to set the parameter name a second time before the parameter is correctly remembered. Is this a bug that has gone unfixed, or is it intended behaviour? (And if so, why?)
TrippyLighting
Not fixed!
