Couple of question about the alignment tool.
First, when trying to pick what you want to align, depending on what your hovering near, you get all sorts of points that display, that look that are snap points? Assuming they are snap points, how do you use them? They never stay visible long enough to move near to snap on.
Mainly I have the problem trying to align the center of a hole with the center of another hole. Is there a key press that keeps them visible maybe?
And the next question, say you wanted to align something to something else....but the way it was drawn requires it to be rotated too. will the alignment tool alow for moving and rotating together? Or will you need to align it first....then rotate .....then re-align...and so on.
For example, align a hole to a hole, and this can be a pivot point, and then align an edge to another edge and have them rotate into place?
Is this possible?
