Bug Rotation axis
Bug Rotation axis
Bug Rotation axis
I think i found a bug.
Trying to repair elements (holes) that are in a circular pattern, I notice that the axes that always come, when a new rotation patern is made, doesn't appear repairing it.
Until now, I found only two solutions:
- Having a construction line, on the same position of the wanted axis
- Delete the circular pattern, and make a new one.
This is not that annoying solving small geometries, but complex patterns is another think.
jeff_strater
Hi @Anonymous,
Could you possibly share your model?  I'm not completely certain what is going on in your model.  It looks like the problem has happened before the video in your post - that some change caused the reference to the axis for this circular pattern to be lost.  What was that operation?
You should be able to select any cylinder, circular edge, work axis or sketch line as the axis for the pattern.
We'd be happy to take a look at your design if you could post it here.
Jeff
Jeff Strater
Engineering Director
Hi James,
Thanks for your reply. The model is now repaired, so the bug is not more possible to produce it again. But as soon I found it again in the same/another model I can send you it.
