Bug on repeating pattern
Hi, I don't know what happen when I try to repeat a pattern on a surface. I tried also adjusting the "compute option", but same result.
Is this a bug?
wilkhui
Hi Rafaal - are you able to share your model?
Indy
Inderjeet Singh Wilkhu
Product Owner - ASM
Autodesk, Inc.
Hi wilkhui, and thanks for your reply.
Sadly can I not share the model yet. Is a "top secret" project.
I tried more times and i concluded, that fusion makes this kind of error when it needs to repeat this kind of extruded patterns (complex patterns as this) all together. I tried in smaller groups and it worked.
Maybe I am reaching the limits of Fusion 😉
Cheers!
wilkhui
How about sharing it directly with me? I can promise that I will keep your work confidential and won't share it internally. You can reach me at inderjeet [dot] wilkhu [at] autodesk [dot] com
Thanks!
Indy
Product Owner - ASM
Autodesk, Inc.
