BUG: in pattern features with 2 components
I created top plate with extrude 2 ways and rectangular pattern and the left "empty" plate.
After joinning both plate i have edit extrude to select body to cut. At this point the extrude feature cutes the other plate, but pattern doesn't. Only if I delete and create same pattern its ok
jeff_strater
yes, that is a bug all right.  Thank you for reporting it.  I can reproduce it.  I will file this bug with the dev team to take a look at.
[edit] filed as FUS-41524
Jeff Strater
Engineering Director
Hi @jeff_strater
I found similar issue with copying componentScreenshot_1.pngScreenshot_2.png
jeff_strater
Thanks, @Anonymous, that does seem like the same underlying problem.  Thanks for posting it.
Jeff Strater
