Bug files disappearing
daniel_lyall
Mentor Mentor
Message 1 of 16
daniel_lyall
I am working with @oldtbone55 on some guitar stuff He invited me in to the file where the sketches are, and some sketch file have disappeared.
When I was finished last night the files where there I let fusion finish the upload on the 3 files I was useing (they are still there now) then closed fusion down, when fusion closed it spat out a error, I can rember what is said, I have attached my diag log files I will get oldtbone55 to do the same thing, can someone please have a look.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Replies (15)
Message 2 of 16
oldtbone55
I've attached my log files as well. I've also submitted them to the support team as suggested in the report bugs/errors. Daniel, you might want to submit them as well. They have an e mail you can send them to, [email protected]. I've already received a reply with a case number.
Message 3 of 16
masa.minohara
Thank you for posting! I had a look at the log file but unfortunately I was not able to find out what caused the issue. @oldtbone55 mentioned in the email that the files are showing up now. Are you able to see files now as well?
Also, let me just check - were you able to see the designs in the project but the designs did not contain sketch in them? Or you noticed the designs that contain sketch were not showing up in the project?
I am not sure if this is related but I see some network error in the log file and that might have caused a sync issue. Could you check the time stamp of the design to see if the time the design was saved matches what you expect?
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
Message 4 of 16
oldtbone55
The name of the design could be seen in the project but the sketch could not be seen in one case. When I opened it the canvas was blank whereas last night the sketch was there. Also, none of the changes that had been made to one of the other designs appeared. Where do I find the time stamp for the design?
Thanks.
Message 5 of 16
daniel_lyall
What came back for oldtbone55, only came back after I opened and closed the files this morning what I was working on last night what where the 3 files closed at 8 pm on the 2/9/2017.
@oldtbone55 is the file you are not see the canvas on point to point move to Aline top & bottom sketches -me, if it is this one i am not able to ever but I bet if I break link I will be able to see the canvas, I will do a save as and change it's name so it's a new file.
Daniel Lyall
The Big Boss
Mach3 User
Message 6 of 16
masa.minohara
Hi @daniel_lyall and @oldtbone55,
Thank you for your response. I assume you experienced a temporary sync issue. If this happens again, could you try switching to offline mode, open the file in the data panel and save a new version, then going back to online mode to see if the files get synced properly?
For oldtbone55, the time stamp can be found by clicking "Click here to see versions".
Masanobu Minohara
Message 7 of 16
daniel_lyall
The sink issue is what I would like to know about, what the error that pooped up was and what if anything I can do to stop it happening again.
Daniel Lyall
The Big Boss
Mach3 User
Message 8 of 16
masa.minohara
Hi @daniel_lyall,
Honestly I am not sure what error message you received since I was not able to identify the root cause in the log file. Sync issues are usually associated with internet connection problems and switching offline/online mode works in most cases. In case the issue persists after trying switching offline/online mode, I believe there could be something else causing it so please send us diagnostic log files and screenshot of an error message if you receive any.
Masanobu Minohara
Message 9 of 16
daniel_lyall
Thanks @masa.minohara If it comes up again I will try and pull a screen shot thanks for your time.
Daniel Lyall
The Big Boss
Mach3 User
Message 10 of 16
daniel_lyall
the error has come up again. this is it there is a error report with it as well but it does not have a number.
I have opened fusion back up again to get the Fusion360 Diagnostic Logs it's attached.
Daniel Lyall
The Big Boss
Mach3 User
Message 11 of 16
masa.minohara
Hi Daniel,
Thank you for the screenshot! I will try to find out what is causing this issue.
Are you also seeing the disappearing sketch issue right now?
Masanobu Minohara
Message 12 of 16
daniel_lyall
Not that I know off, I am sure it was something at my end, it would be good to know what it was.
Daniel Lyall
The Big Boss
Mach3 User
Message 13 of 16
masa.minohara
Thanks, I will circle back here as soon as I have more information to share!
Masanobu Minohara
Message 14 of 16
daniel_lyall
@masa.minohara Thank you
Daniel Lyall
The Big Boss
Mach3 User
Message 15 of 16
masa.minohara
Hi Daniel,
I'm sorry for my slow response. It seems like the error message is not related to the disappearing files issue. I learned that indicates an incorrect installation or configuration of an Autodesk product. When an Autodesk app crashes, it puts the UPITOKENs for installed software in the report, this error means an app didn't provide a valid token. We are examining some Fusion 360 crush reports that don't have UPI values at the moment, haven't worked out why it is happening.
Masanobu Minohara
Message 16 of 16
daniel_lyall
@masa.minohara It's all good thanks for letting me know
Daniel Lyall
The Big Boss
Mach3 User
