BUG: Extrude taper rotation length
cekuhnen
Mentor Mentor
Message 1 of 9
cekuhnen
at 90 degree the surface disapears and the 90 number is red!
this should work like the make draft in Alias.
also adjusting rotation changes the extrusion length
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
Replies (8)
Message 2 of 9
WHolzwarth
How did you create the 3DSketch at the start, Claas?
Walter Holzwarth
Message 3 of 9
cekuhnen
I made a sketch curve and then moved the spline perpendicular away from the construction plane with the move command.
I did the same fro the back curve and the C that hangs down. then I drew the side splines by spanning to the end points.
Claas Kuhnen
Message 4 of 9
cekuhnen
Here is a video
https://docs.google.com/a/ckbrd.de/file/d/0Byzv_NlyKp_2bDBmcmd6aUpZMG8/edit?usp=docslist_api
Claas Kuhnen
Message 5 of 9
WHolzwarth
Hmm. I'm just trying to follow-up your workflow.
I'm seeing some differences in the grid settings.
On your video I can see sub-grids well enough.
But not on my sytem
I'm on Windows 7 with an AMD/ATI FirePro V7800 card. Are you on a Mac?
Cheers
Walter
Walter Holzwarth
Message 6 of 9
innovatenate
Autodesk Support
Autodesk Support
The extrude command is measuring length in the direction of the normal. As you change the angle, the surface has to extend to match the length according to the normal direction. Compare the images below for reference.
This may help also explain why this command works when the taper angle is set to 89.999 deg and fails for 90.000 deg. At 90 degrees the distance must be 0 in the normal direction!
Instead of using the Extrude command, a better command bay be to use the Extend Surface command from the Modify drop down menu in the Sculpt environment.
If the results aren't what you had in mind, another solution is to loft to another straight sketch line. I did a copy and paste in the original sketch to get the line in just the right position. This ended up being a pretty quick solution.
I hope this information helps! Please let me know if you have any questions.
Nathan Chandler
Principal Specialist
Message 7 of 9
cekuhnen
Hi Nathan,
Thank you for explaining this. Looks like the Fusion devs have to give the code/algorithm some loving.
It is a pretty standard feature to extrude and taper/rotate the direction. Fusion is the only app that seems to fail at this I know.
Take a look at the make draft tool in Alias. Thats honestly the way it should work. Everything else are time consuming work arounds that add additional complexity and their own pitfalls.
http://knowledge.autodesk.com/support/alias-products/learn-explore/caas/CloudHelp/cloudhelp/2014/ENU...
Claas Kuhnen
Message 8 of 9
innovatenate
Autodesk Support
Autodesk Support
I thought of one more solution to this! Check out this screencast for further details.
http://autode.sk/1PuzWcx
The normal direction in this case is based upon the original plane that you started the sketch on. If the sketch was originally placed on the XY, then the extrude direction would have gone along the Z axis. Unfortunately, the Patch Extrude does not seem to have all the bells and whistles of the create draft surfaces command in Alias. For this instance, an IdeaStation request would be the best way to share the love. 🙂  Feel free to promote the Idea here, I will give it a Vote!
Please let me know if you have any questions!
Nathan Chandler
Message 9 of 9
cekuhnen
Already added an idea. I think the current approach with the patch normal is not really that useful because of its limitations.
Claas Kuhnen
