Hello
Just came across a bug.
As I set the dimension for in my sketch the dimension lines show but the caption with the actual dimension digits in it disappears. And sometimes, even the entire dimension lines disappear.
The sketch lines are black which means the dimension is set but I cannot see them anymore.
Tries closing and restarting fusion but no luck.
The only work around it is to scrap the entire sketch and create a new one.
Any ideas?
The sketch in question is axle side
I am attaching the file.
Solved by laughingcreek. Go to Solution.
For me it worked by deleting the dimension and re-measuring it.
However, I once have also observed the same behavior.
I would agree this seems like a bug.
but you don't have to scrap the drawing to work around it. when this happens and the dim seems to disappear, it's actual just hidden behind some other geometry. you can find it by long left clicking in the area it should be, selecting it from the pull down, and deleting.
Thanks for the idea! I haven't been able to reproduce the bug but will definitely try it when it happens again.
