Browser WIndow
Browser WIndow
SGoldthwaite
Browser WIndow
SGoldthwaite
For some reason my browser is now in it's own floating window.  How do I get it back so it's not in it's own window?
AnandSomani
Hi @SGoldthwaite,
You can select the browser window by its title and drag it to the very end of the left side. You can see a green highlight there suggesting that it will snap there.
Once snapped, it will look like it used to.
Thanks.
Anand
(Autodesk Fusion Developer)
TrippyLighting
I am not on my Fusion Station at the moment so canot post a screenshot, however, there is also an option or menu entry somewhere that allows you to reset Fusion to the original layout.
still cant find it...
@AnandSomani wrote:
Hi @SGoldthwaite,
Thanks.
AnandSomani
Hi @Anonymous,
Welcome to Fusion 360 Forum! 🙂
The green highlight should show up when your cursor reaches the left-most side of the window. Please try dragging the browser window until your cursor reaches the end.
However, if that still doesn't work for you, you can always go:
File Menu -> View -> Reset to Default Layout
Thanks.
Anand
I have found the answer myself by searching half a day!. your answer is not right.
answer is. on toolbar go to wiev and show browser. that is it.
but thanks anyway. I should have known this from outocad 🙂 same idea
