Broken link warning
Broken link warning
Broken link warning
When I first started creating this design, each item was a separate component, but that got to be a hassle so I moved them all into a single document and broke the links.  ALL were the most recent versions.
Yet I get this warning link in the top and I have no idea how to get rid of it.
Can I?
daniel_lyall
Have a check in side the components to double check there is no chained items.
are you able to post the file, if you don't want to you can weight for a Fusion staff member to come along they do NDA's
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
HughesTooling
Have you used Remove on any components to remove them from the timeline? If you have the component is still linked, you'll need to suppress the Remove then update that component.
If you click the triangle in the title bar do you get this warning.
Mark
Mark Hughes
Owner, Hughes Tooling
There shouldn't be any sub components, but I'll double check.
That's word for word in the dialog box!
I'll have to do that.
Thanks very much!
